Classic III dropping handle problem
gj3476
Prosper,TX
I’m not sure if I mentioned about this before for my Kirby Classic III but it has a bad case of dropping handle and I believe it needs a new handle spring. Should I buy a new handle spring or take it to a Kirby shop? I also have a another Classic III being used for parts and it has a handle spring that works still.
Gj3476
Gabriel,
I am facing the exact same issue with my 1984 Heritage II! And like you, I attribute it to a weak handle fork spring (in my case, I may use the good handle fork spring off of my parts Tradition).
Order part no. 137073, if necessary.
if you dont feel confident in advanced repairs
i wouldnt recommend it. a decent amount of strength is required to de-tension and re-tension the spring and if you dont apply constant pressure, the yolk will slam down on your wrist. its not a repair to try if youre not 100% sure you can do it. ive done it several times but did have a yolk slam on my wrist doing a tradition once. it hurts like hell. if you do try to attempt it, have someone to help you your first few times. i did.
If you use used parts, inspect all pieces carefully so you won't have to redo the job later. On a D50 I had the long tube wear from the spring riding on it at one point and it snapped in two. The spring itself was fine.
I have tensioned a few springs by holding the case with my legs and feet and twisting the side tab with a STOUT pair of needlenose pliers. It takes a very strong wrist to do it one-handed and getting it to lock in the slot with the other hand is tough. It CAN be done though if you have the strength and will power. If you have a helper, this would be much easier - two hands on the pliers and another to use a screwdriver to pop the tab into place. Since my hands were on the tools, they were safe. I do recommend eye protection in case the tab slips from the pliers, a small sliver of metal may launch.
If this is beyond what you want to do, take the new parts and the case only to your local shop and they may do it at a low price while you wait, or maybe for free if you buy a pack of bags or such (I know my shop would).
TexasKirbyGuy, is your local Kirby shop located between Parker rd and Custer rd? I’ve been there before and it’s a nice little shop! That’s where I got my ‘71 Classic 1cr for about $25.
Yep, you know where the shop is!
The last time I was there (last year) he did not have new handle spring kits but he does have a huge collection of good used stuff, though.
If you want new, call in advance to order or take your own. Take a list of other stuff you might want, as well.
He has many working parts units from 84 and older for about $25 each or so. More you buy the cheaper they get. Many Traditions and D80s.
Fun place - enjoy!
I will be there in a couple weeks or so.
I got a brand new handle spring assembly on eBay and was delivered yesterday. I’m thinking about taking this and the Classic III case to the Kirby shop soon.
I’m gonna try to place the new part on tomorrow but I gotta go to work now. So far I managed to remove the old part!
The only thing that was a pain was turning the locking part with a pair of pliers. Know what I’m talking about.
"The only thing that was a pain was turning the locking part with a pair of pliers. Know what I’m talking about."
I know exactly what you are talking about - I have done it a few times...
Glad you were able to DIY!
You should still go on down to the shop some time just to get some more vacs to work on..........
:o)
