fantomfan57
Shetland-Lewyt 2349-J Improved with Lamb motor, BUT....
The cordreel system is not good. To stop the cord from retracting, the designers used a pedal, connected to a shaft, connected to a flat piece of metal with a slot cut out. Basically the cord runs through the slot and when the pedal is released, it "bites" into the cord outer sheath to stop it.
What ends up happening is the cord sheath gets nicked and eventually cuts through.
The Cord reel is strong and usable, but the stop is badly designed.
1. Would you slip on and glue something on the tongs of the slotted metal stop to soften the surface? Would you then re-cord the cord reel to eliminate the damage?
2. Remove the cord reel completely and go with a standard wrap around the body cord.
I really would like to know your opinion.
