Canisters that Agitate
shrink1982
Active member
Indianapolis
Does anyone know why canister vacuums with a PN don't seem to agitate very well? For example, my Sebo D4 Premium has an excellent brush roll but it doesn't cause the carpet to vibrate the way the Kirby and Maytag 1200 do. There is a bit of agitation but nothing compare to the above mentioned machines. What is it that makes a vacuum agitate well? I know the obvious answer would be brush roll but I don't see anything special about the Maytag or Kirby brush roll. The Sebo has a really nice, stiff bristle brush roll and it would seem that would be excellent at grooming the carpet. Any thoughts are appreciated.
Both the Maytag and Kirby have wheels directly behind the brush opening, that move up or down to set the height to the carpet. They keep the brush opening parallel with the rug. This allows the suction to 'lift' the rug slightly off the pad or floor, and thereby the brushes can 'beat' the carpet on a cushion of air. Old principal, very old.
The power nozzles must bring the brushes to the rug, since the nozzles don't all adjust the same as uprights, and the airflow is less strong compared to uprights like the Maytag or Kirby.
I concur with Tom
I also agree with David and James. The weight of the upright tends to hold the rug nozzle in contact with the carpet, whereas the lighter power nozzle tends to skim the surface.
I agree that it is because the PN has less weight than an upright and uprights tend to suction seal to the carpet, at least in case of fan before bag machines.
Tom has a point there. But, it doesn't just depend on how the brushroll is designed, but the design of the powerhead's base plate & how far the brushes extend out the bottom. Take the Wessell Werk EBK360 for example, it is one of the current powerheads with the best agitation on the market....look at how the brushroll & bottom plate are designed, & it's no coincidence.
There is also ways of adding weight to the powerhead so it digs down into carpeting more. The Wessell Werk powerheads use metal weights inside, as I am sure some other European powerheads do. And the current TriStar MG Series powerhead, as well as the previous TriStar CXL powerhead, both have a metal top that adds some weight. This would certainly help make the brush dig into the carpet more aggressively & clean better.
My Royal/Starks 4650 will pull up the carpet and agitates pretty darned good. I see crumbs and things bouncing around as they get close to the power head. Obviously the weight advantage for an old school upright is a huge advantage.
We had Kirbys a few times as a kid and I remember them being loud, heavy, but working well and all the fancy attachments. I really like my Royal canister vacs but will probably pick up a Royal upright when money and a deal comes up. Why not, we have mostly carpets and a parrot who thinks his seeds and things must be dropped to the jungle floor to feed the little creatures below.
My grandmother has a Hoover Spirit with the QuadraFlex PowerMatic Head with the headlight and a metal brushroll with beater bars. That vibrates the carpet quite a bit. I know you guys were talking about modern canisters, and, on top of the lack of weight and airflow, most of the brushrolls seem to be wooden affairs with soft bristles and no beater bars. I feel like a brushroll they could put in there would be a Bissell brush roll. Minus the seizing caps, of course.
The answer is simple..
And your totally right about the fact that Kirby and Maytag have fairly "normal" brush roll. The reason direct air uprights have such good agitation is because of their airflow. It's airflow not suction that lifts carpet off of the floor and then as the brush sweeps the carpet, the carpet is quickly pushed away from the nozzle and then snaps back and this is what actually is happening as the vacuum is agitating the carpet. Most clean air style vacuums don't make the amount of airflow needed for a lot of agitation and that's why machines like your canister produce less agitation.
I thought the brushroll vibrates the carpet which makes the dirt bounce out of the carpet. With good agitation you can see this happening ahead of the floor nozzle.
Canisters such as the Riccar Immaculate hae great agitation.
reply
If you want a good power hrad my opinion iws to go back in time and go wht a metal Compact or Tristar puta vibra groomer 2 brushroll and man youve got a cleaning beast on your hand granted to use a micro filtration enviro care bag.On the modern side of thing Aerus or filter queen cant beat a metal canister. Heavy but built lieka tank.
this leads to a question
Is whether a carpet has that groomed look directly related to how well a vacuum is removing the dirt from that carpet, or is that unrelated, and just makes the carpet look better? No doubt about it, cleaning carpets is more involved than cleaning hard floors.
Mike
There is well agitating powerheads
I made video of my full size powerheads (Wessel Werk EBK 340 & Electrolux Paragon) compared to the Kirby Gsix agitation. Kirby is better, but those powerheads will agitate quite well.
Wessel Werk EBK 340 is universal ph made for many different vacuum brands and Electrolux Paragon comes with the UltraOne and UltraFlex. I have UltraFlex.
Mike
Yes Wessel Week PNs agitate very well. The Miele 228 is made by Wessel Werk I think I'm not sure who makes the 236 but they both agitate very well. I've seen videos of the Riccar PN and that seems to agitate even better than the Mieles.
And yes you can get good agitation from a canister PN.
What about this one?
It's an old Eureka upright converted into a tandem air power nozzle for this Eureka canister. I imagine it would agitate the hell out of the carpet with that Dial-A-Nap and VibraGroomer!
First pic is nozzle
Second Pic is canister
Both are not mine, nozzle is luxflairguy's and canister is Kirbyveritbles'
Wessel Werk Nozzles
Both the Miele 228 and 236 are made by Wessel Werk, the 228 is basically the EBK360 without the headlight, and the 236 is the same as the EBK340, they are modified to fit the Miele hose and electrical connections. Another great power nozzle is made by Lindhaus, it actually has 10 height settings.
Mike
