CANDIED MIXED NUTS
electrolux137
Bronze Member
Los Angeles
CANDIED MIXED NUTS
This recipe is very easy and very tasty. The only trick is to get the sugar mixture to just the right degree of "melted-ness." If it's not melted enough it will be grainy and won't stick to the nuts; if it's too melted it will get too hard and brittle to coat the nuts.
1 cup coconut palm sugar
1 tablespoon butter
1/2 tsp cinnamon
1/3 cup agave syrup
1/2 tsp vanilla extract, stirred into the agave syrup
1 16-oz. bag roasted & salted mixed nuts
Combine sugar, butter and cinnamon in a heavy saucepan. Simmer on medium-low heat, stirring constantly with a wooden spoon, until slightly browned and gently bubbling.
Remove from heat and add the agave syrup, wire-whisking to incorporate. Add the nuts and stir with a spatula until the nuts are evenly coated.
Lightly butter a nonstick baking sheet (yes, you read correctly). Pour the nut mixture onto the baking sheet. Press down evenly with a rubber spatula. If there are stray nuts around the edges, push them in. When it’s started to cool a bit, dip the edge of the spatula into some softened butter and press the sides in to make the mixture somewhat square.
Allow to continue cooling for at least a half hour. Cut into approximately 1.5” squares. Serve in a bowl lined with wax paper.
To store: Wrap in waxed paper and then put into a large baggie. Keep it in a cool area away from direct sunlight, or you’ll have a big gooey mess on your hands.
Stuffs chocolate in mouth...
That looks absolutely delicious! I haven't had much lately, but every year some of my relatives would have a candy making party, mom went a few times but its been years.
Takes bite of cookie...
