Yesterday, I figured out how to dismantle the brush roll on my Bissell Pet Hair Eraser Lift-Off vacuum, which isn't turning smoothly. I popped off the end caps using a small, flathead screwdriver, and there was quite a bit of hair wrapped around the inner axles.
After removing the hair, I was able to pop the axle caps off the ends of the brush roll. From that point, I could slide the main axle out of the brush roll, where I found the culprit: one of the bearings isn't turning smoothly!
Now I'm going to need to lubricate this bad bearing. I've got WD-40 as well as 3-in-1 Motor Oil on hand; will either of those do the job?
Also, are any of the brush roll parts washable? Because the inside of the brush roll is coated in dust.
