Bissel vacuums Good or bad
gsheen
Cape Town South Africa
Why does it seem like bissel has such a bad name in the states . well amoungs vac guys any how.
I own a proheatx2 and am pretty impressed with its cleaning abilityI also own a healthy home and the lift off.
The healthy home is a big big machine it works well, has a vet agressive brushroll . It doesn't filter aswell as they say it does so the hepa gets clogged fast and its non washable so you have to keep replacing them but for the price I thoughtit was not bad.
We are Bissel repair agents but only sell the carpet cleaners.
What are your guys thoughts on them
I think Bissell vacuums are OK if they're looked after and maintained well, but if you're a regular user who expects a vacuum cleaner to keep performing well without routine maintenance then they are prone to an early death.
I've had several Bissell carpet washers and a couple of uprights and found that they performed well. I had a Proheat 2X which was excellent at cleaning with it's two aggressive brushrolls, but it didn't extract as much water from the carpet as my Vax Oasis (Hoover Steamvac) or Vax Dual V. I liked the fact that it was considerably quieter than the Vax models though. My Proheat stopped spraying solution as it got clogged up inside but I managed to fix it. The Bissell shampoo tends to leave a residue inside the machine so it really should be flushed out with clean water after every use, but most people wouldn't bother, hence the common problem of the spray not functioning. The parts for Bissell cleaners seem to be widely available in the UK and reasonably priced, so if a problem did occur, I knew I would be able to fix it without spending a fortune.
I have owned a Lift off, Momentum and Easy Vac. The Easy vac was more like a toy and the filters got dirty really quickly. I think the concept of the Lift Off is a very good one, but without a decent cyclonic system the filters needed regular cleaning. The Momentum was really effective at cleaning and I enjoyed using it, but again the bagless system needed regular cleaning. What I like about Bissell uprights it their aggressive brushrolls. In the UK most brushrolls have very soft brushes these days and I prefer a stiffer brush. The Vax Mach Air for example has a much softer brushroll than the Hoover Windtunnel Air.
Bissell only has a small range in the UK compared to the States and I think they are more known here for their carpet washers. Their best selling upright is probably the Powerforce bagless which currently sells for £45 ($69) at Asda Walmart and would mainly attract consumers who want to spend as little money as possible on a vacuum cleaner and don't care who makes it as long as it picks up the dirt. Unfortunately these people tend to be the ones who don't read the instructions or bother to maintain the cleaner and wonder why it doesn't pick up as well as it did when they bought it a few weeks ago. It will get returned to the store who will just refund the money so they can buy another cheap vac that will clog up and the whole cycle will start again.
So as I said earlier, even when you're spending only £45 on a Bissell upright, it is possible for it to last two or three years at least, providing it is looked after. Obviously, the best vacuums are the ones that last even when they are not maintained correctly, but even a reliable make like Sebo or Numatic will perform better if simple regular maintenance is performed on them.
We have a tiny range here in SA, 3 upright vacuums 3 carpet washers and 3 canisters. lots of chemicals that are great.
We do not get the vax or hoover range in SA, just really poor made machines badged as hoover.
Gareth,
When I have someone looking for a cheap vacuum I will always send them to a Bissell bagged machine. I am not fond or would I ever recomend a bagless machine to anyone.
I find that the 39.00 version of the Bissell bagged machine, cleans well, has a good brush roll. The attachments are less than desirable, but for people who live in small apartments, college students, I find it to be a very practical machine.
I have allergies and a bagless machine defeats the purpose. Empting the container sets my allergies into a tail spin. I have found that the normal consumer doesn't take care of a bagless machine, They dont' check the filters, they don't keep them clean. The price of filters verses bags...is much cheaper.
Just my thoughts.
That is one annoying aspect of Bissell UK - they don't sell a bagged upright version of the Powerforce. I didn't like the Easy Vac at all either, the bin was always difficult to remove and put back (and I agree about the filter removal too) but not only that, it wasn't so easy to push unless you remove the squeegee strip on the underside by the roller brush. A few people I know who have had Powerforce bagless uprights tend to have hose breakages early on, but the points made by Sensotronic & Vinvac are spot on - many buyers who buy the bagless vacs seldom look at the after care or maintenance and more so if they have pets, they may well tidy up the mini turbo brush, but not the main roller brush - but that can be applied to any brand who offer a cheaply priced bagless vacuum.
[this post was last edited: 6/2/2012-15:11]
Oh trust me I know all about cheap bagless vacuums. I have tons of them in my back rooms , I always tell customers if you want bagless get the best one, dyson in my opinion if you can't afford it then stick to a bagged vacuum. We do sell the Electrolux powerglide and airspeed , while not perfect they seem to not clog up as easily as other cheap bagless vacuums
Gary I too would say stick to bagged if not a Dyson bagless, but certainly in the UK there are now very, very few bagged cleaners to choose from, which I find a bit sad.
Unless you are choising a Miele sebo or vorwerk there are no bagged upright vacuums in SA anymore. those Electrolux powerglides are actually very good, customers rave about them even after a year or two of ownership. Most people come in and buy a new filter once a year, and they cost less than one pack of bags that would only last you half the year.
Bags are also hard to find, most stores don't stock them any more and theer are very few vacuum repair shops here these days, people prefer to just buy a new vacuum, its less hassle , no waiting for a repair and easier too.
In fact the only reason we sell sebo's is my commercial trade, home owners here do not want bags at all.
I wouldn't like to say whether or not the UK is totally wanting bagless cleaners or not, as I just don't know. I have heard that sales of Numatic cleaners are high though. I think much of that is because they make few promises and do what people buy them to do. The bags are widely available and not hugely expensive. Panasonic bagged uprights were always a very popular choice here too.
Yes they were, but they seem to appear seasonally at Comet, Currys et al. Panasonic haven't really updated them, only putting new colours and then raising the "watts" 100 at a time and their later one now is 2000 watts I think. Last one I tried was a 1700 watt but they're too over priced for what you're getting. They're okay for what they do but I'm not a fan of Panasonic's bagged uprights now - the tools are really poor quality, the noise level is too high, too much hot air out the front, hose isn't protected at the back and the 2 drive belt principle is too old fashioned. Single belt drive would be simpler. I had a few of the bagless uprights during the 1990s, like the Twin Bin ones. Panasonic could really do with bringing back the on/off brush roll feature that their older bagged uprights had. The Electrolux Powerlite is another good upright but it too suffers from poor plastic. Brands are obviously happier to do the bagless route using better quality plastics in some cases compared to the not-so-durable plastic on offer for the older bagged models.
Effectively then what the brands are doing is moving away from bagged uprights, pushing buyers to sway to other brands with products at higher prices like the Miele S7, Sebo X1.1/X4 or consider the bagged cylinder route - and I don't think that's necessarily a good idea.
A few years ago I did buy the Argos bagged upright vacuum - they're basically Vax machines under the Argos label - and I found it to be pretty good on performance, not bad on the noise level and simple to push but obviously very plasticky. Really annoyed that it didn't come with a dusting brush but soon found a Dyson round upholstery brush could be stuffed at the top of the crevice tool for storage and use whenever required.
The downside to this model apart from looking like a toy is that there's a lot more assembly that you just wouldn't believe (you have to screw in 4 screws into the dust chamber together to the main body, then both that to the motor head, then the handle to the machine, then a single clip to hold part of the hose at the back in as well as a clip for the single extension nozzle !) The other major downside of course being Argos Value is that the bags can only be purchased from Argos. It would be good if Vax had their own version out like Bush have done which is the same model but with a H filter, different colour and mini turbo brush.
My favorite Bissell...
is the Pro-Lite Multi-Cyclonic Bagless. Center dirt path, extendable hose, bendable wand, more complete attachment kit. Not bad at $149.99
I see a lot of them being turfed away at the local dumping site. Mostly, the Powerforce's main problem seems to be the hose and handle, either coming away from the hose itself or splitting. It isn't uncommon to find that the sole plates shatter or are cracked, too or broken wheels off the base chassis. The smaller cleaning tools seem to last longer than anything else.
It's not always like that of course. In the UK where Samsung's Propel uprights are similar to the Powerforce by Bissell, the handle on the Powerforce has a better quality feel in my experience than the hollow feeling of the Samsung.
I have to say I don't think the Bissells are too bad. I used a basic bagless Powerforce once and was quite impressed. It was lightweight so I could push and carry it easily. It also groomed the carpet well. It seemed to be quiet, but that could have been the acoustics of the area I was cleaning. The only thing that I saw that could be better was the cord length.
Of course, cleaning the filters is a messy, and as mentioned often overlooked part of these. I think the bagged Powerforce would avert this issue, yet have all of the good things of the Powerforce.
Really, for the price, they don't seem bad. I probably would not buy one to use as an everyday machine for myself, but I could recommend one to someone needing a basic and cheap vacuum.
I can only speak for myself on this, but...
The reason I tend to dislike Bissells and other similar machines is the fact that they are typically poorly built in comparison to other better machines. Set it next to something like a Miele, Sebo, or Riccar/Simplicity and you'll see what I mean. I also don't car for bag less machines other than water filter vacs all that much. They tend to be very dusty to empty and clean out compared to just tossing a bag out when its full.
I work with vacuums in the, ahem, secondary market. I only "do" a couple of Bissell models. By far and away the more numerous is the Lift-Off. Due to their rather unique capabilities courtesy of the design, they are very popular and easy to sell. The other model I do occasionally is the Healthy Home. The latter are not as numerous as the Lift-Off. Once in a while, I've done a Cleanview or a Rewind IF they were in unusually good condition as a core to be refurbished.
When I sell a Bissell bagless, I carefully go over the filtration system with the customer and emphasize the importance of keeping it clean. I point out that Bissell foam filters are some of the easier to clean, but require it more often. The Bissell foam filters used in bagless products are less than adequate unless the consumer doesn't mind the frequent cleanings that are necessary.
My own personal opinion is that the materials used in most Bissell products aren't as robust as some competing price point makes. The Lift-Offs come from Korea but aren't any improvement over Chinese product. However, some of the bodies and a few small parts are made of ABS which is pretty sturdy. Handles, not so much. Sometimes part design in light of materials used is lacking. Motors are tinny little things but don't start screaming any sooner than Hoover or Kenmore.
Bissell products serve their purpose in their price point. Personally, I'd rather have a Hoover Tempo made in Mexico for $100 than just about any new Bissell bagless.
