Aqua-Air Central Vacuum System
panasonicvac
Northern Utah
Recently I had the opportunity to go to a Aqua-Air dealer to try these out for the first time and I was actually really impressed. Their basic model which was the 130 is even better than my system. I knew about Aqua-Air for quite sometime now but I never paid much attention to them until maybe a month or two ago when I saw one of these in a foreclosure home and I started to learn more about them. They can not only vacuum but they can mop, carpet clean, and even pick up emergency spills. What I was really amazed is that they use debris screen bags to prevent from clogging the drain pipe lines and these are manufactured right here in my state! I wonder where have I been this whole time lol. Anyways these are the infomercials of the Aqua-Air System on what it is and what else they can be used for.
aqua-air
I actually bought a wand with a spray jet attached to it, a water hose and a squeegee attachment from them, I connect the hose to the faucet and attach the wand to one of my wet dry vacs or one of my water filtration vacs to scrub my hard floors, works great. Drainvac also makes a similar system, if I ever buy a house, I would probably get a system like that.
Mike
Actually
From what I've heard, Drainvac has had problems with clogging the drain pipe lines because they use a different water cyclonic method and doesn't use debris screen bags like what the Aqua-Air uses.
It was outdated. Although I could've used the newer videos that came out not too long ago but these described more details of the systems. The Aqua-Air first came out in 1990.
