hooverbaby
I've recently won a Vintage Apex upright from the US dating from about 1920. Only thing is the seller is having trouble getting the upper wooden handle off the metal fork below and says he needs to do this to ship within suitable limits.
I emailed him to say I'd give him some advice if he sends pictures showing the handle fixing arrangement in more detail, since I've not had this model before, so can't assume it's just like on the Hoovers.
From what I can see, from the picture that he listed the machine with, is that theres an electrical lead underneath, which probably goes to a removable plug and that the front of the handle fork juts out and has a bit that looks like a screw hole - so it may screw in front to back instead of side to side.
It seems like the problem is that there's a sleeve, which moves when the screw is turned. I was wondering if this might be a threaded stud and part of the handle fork, which has worked loose, preventing removal of the screw..but because I can't see what he's done I can't offer advice, except to say that he could maybe grind off the head of the screw. I can run a nut and bolt through of some sort so long as the main part of the handle and fork remains intact.
I know that on Hoovers, there's either a nut and bolt that goes from side to side...or on earlier models with wooden handle either a bolt underneath with nut in the handle or a thread directly into the handle fork and a threaded stud in the main handle. On the very early ones you have to unscrew the whole handle.
Don't know if any of you guys know what's involved with this Apex?
Stephen
Stephen
