fantomfan57
Requires using a vacuum briefly.
Okay, so sealing the inside is key, and I have already tried spraying the outside only to have the hose stiffen up...the braiding can no longer flex.
So I will try and outside application, BUT, attaching the hose to the vacuum, plugging the wand end, and briefly turning on the vacuum while spraying the sealer on the outside. When done, wiping the excess sealer off of the hose. May take a couple of applications and drying between them for testing.
I am hoping the suction from the hose splits will draw the sealer into each fissure thereby sealing it. Wiping the excess off of the outside will minimize stiffening of the braid.
Care MUST be taken to keep sealer out of the inside of the vacuum.
What do you think?
What do you think?
