For those of you who know about the American Lincoln Super-Sweep, didn't these machines switch from using slotted heads to Phillips heads concurrent with production of the Kirby Classic Omega 1CB and then the Tradition 3CB?
That is, when Kirby changed from screws with slotted heads to those with Phillips heads on the two machines I mention, in the areas I describe as listed below, weren't these same changes done concurrently on the American Lincoln Super-Sweep?
CHANGE FROM SLOTTED HEAD SCREWS TO PHILLIPS HEAD SCREWS:
CLASSIC OMEGA 1CB (1973)
Long screw on front of fan case
Four short screws on motor housing (June 1974)
TRADITION 3CB (1979)
Headlight lens, speed switch and vent seal
SUPER-SWEEP
Long screw on front of fan case (June 1973)
Headlight socket and rear wheel shaft (June 1979)
Thank you,
Ben
SUPER-SWEEP
Thank you,
Ben
