Amazing Trash Find
sptyks
Skowhegan, Maine
<p class="MsoNormal">A couple of weeks ago I came across this amazing trash find.  Sitting next to the Dumpster behind my apartment complex was a Kirby G3 vacuum and a package of paper bags.  Sadly there were no attachments to be found.</p>
<p class="MsoNormal">The machine itself appeared to be in fairly good condition so I decided to take it into my apartment and examine it more thoroughly.  When I turned it on it made a horrible screeching sound and then there was the smell of burning rubber.  I immediately turned it off and removed the floor nozzle.  I immediately noticed that the rug plate was missing. The belt had cracks in several places and was severely stretched out.  The brush roll had lots of human hair wrapped around it and then I noticed that it was completely frozen and would not turn.  Both brush roll bearings were seized up.  I then attached the hose from My Kirby Sentria and turned the unit on again.  The motor sounded very good so I engaged the tech drive transmission and move the unit back and forth.  The transmission worked perfectly.  It was then that I decided it would be worth ordering the parts to get this machine up and running.</p>
<p class="MsoNormal">When I removed the bag several objects fell out of the emptor.  I encountered two pebbles approximately ½ inch in diameter, a nickel , a dime, and two pennies, five screws approximately 1inch long, six or seven small finish nails approximately 1 inch long, and a lot of course gravel.  When I saw all this junk I decided I should take a close look at the fan.  Shining a flashlight into the fan opening I could see that the dark gray lexan fan was pretty well chewed up.  So I ordered a new fan, brush roll, belt, and rug plate.</p>
<p class="MsoNormal">While I was waiting for the parts to arrive, I decided to get out my Mother’s Aluminum polish and try to shine the machine up.  Other than a few scratches on either side of the floor nozzle, the machine shined up pretty well.</p>
<p class="MsoNormal">When the parts arrived yesterday I excitedly proceeded to install them including a brand new HEPA micron filter bag.  When the machine was all put back together, I plugged it in and turned it on.  It sounded much quieter than my Sentria.  I vacuumed all of my two bedroom apartment and the G3 performed flawlessly.</p>
<p class="MsoNormal">Now here’s the question I have for all you collectors on Vacuumland:  What would be a fair asking price for this partially refurbished G3 vacuum with no attachments if I were to advertise it on Craig’s list or Ebay?</p>
<p class="MsoNormal">I would appreciate all of your expert responses.</p>
<p class="MsoNormal">Thank you</p>
<p class="MsoNormal">-Stan</p>
