A Question About Kirby Vacuums Before the Heritage
kirbyclassiciii
Milwaukie, Oregon
Does anyone know why all of the Kirby vacuum cleaners produced before the Heritage have a sudden decrease in load when you lower the nozzle enough to the carpet being cleaned -- that is, the sound of the motor rises in pitch when you lower the nozzle? I know by comparison the Royal's motor sound decreases in pitch whenever you properly adjust the nozzle.
Could it be due to the extra weight of the metal fan? Or the way the nozzle was designed?
The difference is
The Kirby seals to the rug cutting off the airflow,the Royal nozzle never seals so airflow is maintained,the Kirby SOUNDS like its doing more but really the Royal will pick up more...IMHO !LOL
Kirby vs Royal airflow
Ben,
I am not sure what is going on with your Kirby's but the sound of the motor in my D50 Does Decrease in pitch when the nozzle is lowered to proper cleaning height just as you would expect. My D50 Does have a new Amodel polycarbonate fan in it but I don't think that is what's causing the difference in pitch.
Now Kenkart is only partially correct when it comes to Kirby vs Royal airflow and here's why:
It all boils down to Nozzle and Rug Plate design.
He is correct in that all Royals do not seal to the carpet because if you look at a Royal rug plate you will see a notch formed into it on each side which allows airflow to enter on each side when the nozzle is lowered down to the carpet preventing a complete seal from taking place.
Now on the older Kirby's. like my D50, you will not find any notches in the rug plate therefore an older Kirby will form a seal to the carpet when lowered into cleaning position.
 I am not sure when Kirby decided to add these notches or indentations to the rug plate but my Heritage II Legend and both my G3 and Sentria have the notches in their rug plates so that means the newer Kirby's, just like Royals, do not completely seal to the carpet when the nozzle is lowered to the correct cleaning position.
Now after all that, I don't think nozzle and rug plate design are causing your problem either because my D50 acts just like my Royal 8300 and all my other Kirby's. You might want to check your brushroll for wear and make sure it is adjusted for proper bristle length past the rug plate.
I have found the opposite
I find that my older Kirbys get a lower pitch one lowered to the correct height.  This is what we would expect, as airflow and RPMs would dip slightly from the triple-cushioned vibration.  That's really weird that your Kirbys seem to kick into a higher gear as soon as they seal to the carpet???
sptyks
(both videos: KirbyCollector)
Stan,
I wonder if you have seen Thom Stepien's videos of this Sanitronic VII he had sold to "Happy Jiggly"? This one, like your D50, also has the Amodel fan in it, but it also has the bojack F&G bag conversion system. Also like your D50, the pitch of the motor also decreases when in proper contact with the carpet.
The Royal actually does form a seal of such.  If you have a model with an Adjust-0-rite you will be able to watch the seal as it pulls in the button.
How one adjusts a Kirby to the proper cleaning height is you raise it all the way up and then lower one notch until the pitch changes.
Now all of my Kirbys will raise in pitch when adjusted to a very low carpet such as an indoor/outdoor type or area rug.   If you have an area rug you will be better able to observe the Kirby Tripple-cushion-vibration as it lifts the carpet allowing air to enter underneath while the vibration loosens  the dirt from the carpet nap.  On wall to wall carpeting this is not as easily observed but you can still watch it lift the carpet.  Because indoor/outdoor carpeting is usually glued down it can't lift it so it has tighter seal.  You can actually feel the bag and though air flow is decreased, it is not stopped during this time.
I will have to double check when I get home, but I thought  the Kirby Omega had the side ports for edge cleaning as was mentioned, but right now I can't say for sure.
[this post was last edited: 8/22/2016-16:27]
Ben.
Thanks for posting Tom's videos as I had not seen them.
Another thought I just had re: your pitch issue is what type of carpet do you have? If it is short or low pile, that might make a better seal causing an increased vacuum inside the fancase which would allow for higher motor RPM. Just FYI, I have a medium pile plush carpet in my home.
~Stan
Harley,
It is those edge cleaning ports on the Royals that I was trying to describe that are what's preventing a complete or total seal. Even though the Adjust-O-Rite button sucks in, there is still air entering from those side ports that prevent a complete seal.
The older Kirby's do not have the edge cleaning ports,. so they would form a tighter seal on low pile glued down carpet causing higher motor RPM on D50's and D80's and such.
If Ben has thick plush carpet, then I am lost as to what is causing the symptoms he described.
The notches on the ends of both the Kirby and Royal floorshoes are indeed for edge cleaning against baseboards and furniture legs.The notches are not enough to take away the "airlifting" of the carpet for effective cleaning.Now the airlift won't work on commercial glue down carpet-the nozzle has to ahave ariflowing from the top of the flooring to get airflow for removal of dust and dirt.The airlift method allows for the nozzle and cleaner to pull air through the carpet for cleaning.My new Volt powernozzle airlifts my floating carpet like a Royal or Kirby.
Also remember with the older Kirbys
Up to The Tradition, if suction is too strong, you can flip up the headlight hood and adjust the suction relief vent. This disappeared after the Classic III, but was available until then.
Kirbysthebest
I'm not sure I understand your last post.  The Tradition did come after the Classic III (in fact, it was the model after the Classic III).  So, when did the suction release vent disappear, with the Heritage?
kirbysthebest
Harley,
Some Traditions did, in fact, have the suction relief vent. Here's two different nozzle castings that have it intact:
Picture #1 shows the nozzle with the additional post for the top-mounted speed switch (for units before serial #F500000)
Picture #2 shows the nozzle with only the suction relief vent (for units between serial #F500001-F749999)
The one I had, and the ones I sold did not. The ones that did must have been the early runs, as indicated by the pin under the hood actuated power switch.
So in answer to the question, some Traditions did.
In any case. . . If they have a suction relief vent you can use it, if not you can't.
