ajc31980
Active member
HI
So I've been busy this snowy weekend, working on this Kirby 1-CR. This is the model I've been trying to get my hands on for years..... every time I've seen one listed the price was way to high for a machine that looked like it had been to hell and back... I finally found one that looked decent, so I took a chance
. I have to say, this machine is so cool ! ( or at least in my eyes is is). from the outside, it looks so much like my Classic III. but the surprise is under the hood ! with the motor, speed/safety, even the power switch being so much more like a DS50/DS80. At First look, my Brain is like, huh?? What? lol... However this is the main reason why I wanted this model. because it is unique. It even has what appears to be the original roll brush with the metal ends. this is the first time I've seen one of these in person. another reason why I wanted this particular machine. Also the Bag is in great shape ! I'm not one for shake out bags because of bad allergies, but this one was worth giving nice hand washing and lining it with a Kirby HEPA bag. Check out the attached pics. I can't take credit for the idea, I actually got this idea from another thread on here. I tried to find it again and can't seam to find it. so who ever you are, thank you for the idea! I think the person used the idea for a 500 series machine.
For daily use I will install a Mini emptor and A full length zipper bag. but this idea gives me ability to use the original when I want too and helps preserve the shake out bag. I have Few spare Zipper bags (see pics) not sure what I'll use for sure yet.
The only real issue I've had with machine is the bearings, both front and rear. after about an Hour of run time ( vacuuming the first and second floor) they started to get noisy, and as time went on they became louder. I had set of bearings that I actually bought last year for my DS50, that I never opened because I decided to re-pack the bearings in that machine.
So I went trough the struggle of getting the bearing plate screws loose. Actually took the better part of the day soaking them in WD40 and Very much tested my patients ! even vented on FB abut it haha. finally broke them free with my drill. The rest was fairly easy and went as usual. typical bearing replacement. Got the new bearings installed, put everything back together, fired it up and it sounded great! but that was not to last.... after maybe 10 min of run time, they started squealing ! ugh!. so I take it all apart again... take the bearings out, and pop the seal on them to take a look and guess what ? very little grease inside...grrr ( see pics and none leaked out that I could see) so - re-packed packed them and they sound much better with some noise in the rear bearing. I'm afraid it may be damaged now from running on the dry side. The front one is quiet, but feels slitty rough when I turn the shaft by hand. does anyone know of a good source for these bearings other than eBay ? I use to mainly get parts from the EBay seller "Kirby needs" But since Kents Passing the Ebay store is becoming slim pickings. He was always A good guy to get parts from.
I'm tempted to get the updated front bearing plate for this machine. It would at least make finding the front bearing easer.
The other odd thing I noticed on this model is this sort of cardboard divider over the motor with foam padding taped together with masking tape. (see pics) kinda odd. the masking tape was coming loose so I re-tapped it with some black tape. I this really something that was done at the factory? also did the machine have the plastic caps on the motor brushes ?
AJ
AJ
