What is the worst-designed hose you've ever used on an upright vacuum cleaner?
For me, it's on the Bissell Pet Hair Eraser Lift-Off vacuum. I've owned this machine since Christmas of 2018, and it's pretty much been my daily driver. While it's a fine vacuum, the hose is just too short, making it very awkward to use. It gets stiff while using the crevice tool or turbo brush, which in turn makes the vacuum tip over constantly, even in "Lift-Off" mode (due to the hose being mounted up high). This turns a stair cleaning job into a balancing act.
In addition, the hose does NOT stay locked on to the vacuum; Bissell stupidly did not include a locking mechanism for the hose, meaning there is no audible click when you turn the hose cuff clockwise to "lock" it into place. So while using the hose, it has a tendency to detach completely from the vacuum, forcing me to reattach it often. This happened to my sister while she was vacuuming earlier today. She called me into her room, where I then reattached the hose for her.
The other poorly designed part of the vacuum is the telescopic wand; it's short and does NOT stay locked, so it constantly retracts while cleaning, even after turning the collar to the "lock" position as tightly as I can. This is especially irritating when using the crevice tool.
I will say that my Dyson DC07 Animal has a superb attachment system. Its hose and wand (not telescopic) are significantly longer, making them a lot more usable than on the Bissell.
Every vacuum cleaner has its faults, but the hose on this Bissell is just infuriating to use. Thoughts?
