3D printed Hoover 20 blade fan
It's just a download template, you need the machine to make it. I would bring into concern how it would hold up to high RPM forces and not explode into pieces. As I understand, 3D printed plastic is weaker than actual factory formed plastic.
now since I dabble in 3d printing, I've replicated the 500 series kirby wheels, im not sure what the RPM of the hoover elite motor is, I think the standard hoover fans today are ABS or something similar
Materials
I've done quite a bit of 3D Printing and I won't really trust a fan made of normal, home-use 3D printing materials, just because I don't know what would happen if I accidentally suck up something hard. However, there are some services that print with stronger materials (using a laser to solidify powder), which may be able to withstand impacts better. There are also services that can make metal objects based on a 3D Model via methods such as lost wax casting, so it may be possible to create a metal Elite fan if you really desire (However, this may cost much more than the vacuum).
now I know nothing about metal printing but pcbway has these options, now the one thing I will say, i have to agree making a new fan for an older machine might be a headache, another solution would be to look around for a fan that will fit and still work the vacuum even if not correct
Cost is not an issue, you do whatever it takes to repair the vacuum. It's about preservation. That's why people are paying $60-$90 for Hoover Elites now, nobody preserved them and they are all gone, so when they come up for sale, they command big money as people fight to get one.
Vacuumman - A metal fan in a Hoover Elite? That would be awesome if one could be 3D Printed and made for those uprights! The increase in performance and durability would be noticeable.
And just imagine, a metal fan might just give it the same performance as a Kirby or Royal Metal upright with the metal fan. Oops, cue the outraged Kirby fans now for even suggesting that LOL :) .
Metal Fan
I looked on Craftcloud3D and it will cost $136.97 for an aluminum fan and $213.88 for a stainless steel fan. Pretty expensive, but it probably wouldn't be the worst idea if you want something that is more durable.
I got a quote from a local company here, for nylon carbon fiber, should put it on par with a kirby fan, so yeah there exists a means, its just a matter if
A how strong this will be, and the durability life prices are in CAD
as for balancing you could try a lawnmower blade scale, granted if the blade is made or printed professionally it might already be pretty balanced
also im seeing two different fans for the Elite, a 6 blade which was replaced by the 20 blade it seems
[this post was last edited: 2/20/2024-14:58]
The issue with the metal fan would be if the motor is built to take that much weight and load. I wouldn't replace it with a metal fan, there's a chance you would increase the wear damage to the motor or overheat it.
Elite Fans
I experimented a few months ago with this. I took a fan from an Oreck XL21 and expanded the 1/4 hole to 5/16 with a drill bit. No further modifications were necessary. I found the corresponding nut at Menards for less than a dollar. It's a 5/16-18 REVERSE thread.
Measuring suction from the intake with a 7 blade fan read 50" of water lift.
The Oreck fan read around 42". It was only used in the early XL21s that had a split fan case. Later units integrate the fan inside the fan chamber and it's sold as one piece.
I also tried a Eureka Bravo fan, but found it to be too tall even though the diameter was roughly the same.
