Numatic Henry HVR200A
beko1987
Stokenchurch, United Kingdom
I have a dead henry!
£25 from ebay.
From Henry HVR200A
From Henry HVR200A
Dead as a dodo. Only had a few minutes before having to get back to the office, so I:
Put it's fuse into my Meiele S5, which ran fine, so not the fuse.
Took the top cover off (not motor part) and had a look at the wiring to see if I could work out how to bypass the hi-lo feature. Failed!
Will have a proper look tonight, and sort this thread out to the standard you have all become accustomed to, but if anyone knows how to bypass the hi-lo feature so I can see if Henry really is terminal or not, that would be great.
It's rather clean tbh. Came with it's small tools, floor brush isn't ruined and the body isn't bashed about. Light domestic use I think.
Will try to get some garage time later.[this post was last edited: 1/13/2014-09:38]
Hi,
<span style="font-size: medium; font-family: book antiqua,palatino;">Hi Sam, Hope your ok. Not spoke in a while. I've sent you a private msg on here to give you some help.</span>
<span style="font-size: medium; font-family: book antiqua,palatino;">If you need any more help you know where I am. </span>
<span style="font-size: medium; font-family: book antiqua,palatino;">James
</span>
Well, after removing the hi lo Gubbins and making henry single speed...
He works, like new too! As per my facebook post, I think I've narrower it down to the pcb, so will get one of those once ive Confirmed its demise with a multimeter.
However until then the return can continue as normal
With an Eco Henry, I have found no need to use the power boost button, unless there is really heavy soil on carpet or hard floor. I never saw the point of putting the hi lo on either.
Haven't cracked an Autosave open myself yet, but would it be possible to revert one of these back to the earlier style manual hi/lo switch? If the parts fit, and cost roughly the same, I know which I'd prefer.
I think the switch would fit, so if you knew the internal parts you need I'd say an old sdtyle hi lo switch would work.
See if these pictures help you...
Having confirmed with a multimeter that the switch works, I bought a new PCB yesterday, so hopefully that will turn up tomorrow!
Thought I'd better get this thing stripped down then
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
One stripped Henry! The design hasn't really changed but the build quality has! There's burrs of plastic on the cut edges, random rubber squirted in the front of the motor plate and carbon dust everywhere. Dont remember my 1995 Henry having that much of a messin there!
From Henry HVR200A
From Henry HVR200A
From Henry HVR200A
From Henry HVR200A
From Henry HVR200A
From Henry HVR200A
Everything was washed, and the new plastic water beading returned with gusto, so nice to see it wasn't too bad.
All dried now, will try and start re-assembly today. Can't get too far until the PCB arrives though
From Henry HVR200A
Can't believe that much dust and fluff accumulate under the metal sole plate on the floor head, I'm tempted to strip some of my floor heads down to see if they are the same. I'm sure the Henry will look good once you've finished!
TBH I've seen worse! Seems to be a trait of this style floortool. Had some Vax 121 ones apart that were so packed the metal soleplate had to be prised off!
This one however is very clean now yes? (Borat voice?)
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
Missed a bit
From Heney HVR200A
Found a new hepaflo, so donated it. Won't be selling it with a box of new bags I've decided.
From Heney HVR200A
Gave the filter a good vac off with my other Numatic
And set it down on the wall 'o' shite ontop of my yellow base
From Heney HVR200A
Put the cord rewind back together
From Heney HVR200A
Ratings plate shot for the motor nerds!
From Heney HVR200A
From Heney HVR200A
There were blobs of rubber like this all over it, and the bumpers were starting to peel away at the edges too
From Heney HVR200A
From Heney HVR200A
That's as far as I got, as I'll need the new PCB to finish the job, which hopefully might be here tomorrow.
I do have a steam cleaner, but don't use it on the vacs. It's not that great, all I'd end up doing is chasing dirt around, it is a PITA to set up and I'd burn myself alot!
Quicker under the hot shower with a selection of brushes and a nice strong mix of G-101!
The PCB arrived! Is a red 4 post one, but the design may have changed since mine was built of course. Hopefully these ones are a bit more robust!
From Heney HVR200A
From Heney HVR200A
Sorry, 'Service Item'? So all the dead machines just need servicing?
From Heney HVR200A
This is handy, was worried that I couldnt remember where the wires go. Hope it helps anyone else wanting to fit the old style hi lo switch
From Heney HVR200A
Re-assembly can continue tonight then! Then I'll find out the switch is also broken or something equally annoying...
That Henry looks fantastic! :D You do such a smashing job making them look new :) Well done
As the the Hi lo switch,
And so Henry's second life begins
After work, I got the new PCB in
From Heney HVR200A
All wired up
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
It was slightly annoying having to fully reassemble it before testing, but had to be done really.
and.....
Yey! Saved for £15!
Gave his hat a celebratory polish and wax
From Heney HVR200A
Even George joined in the celebration
From Heney HVR200A
And the finished article
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
From Heney HVR200A
Already for sale! If I had the space I would keep him, but the money would be far better tucked away in our deposit fund! Besides, with the 'service item' failing, hopefully we will see lots more cheap henries!
Or not, as now you all know how to fix it.
Ah...
Interesting. You don't show a pic of the old PCB that you removed?
I opened up my 2011 Autosave model, and it appears that the PCB it has -part 208428 has been superceded by the part you show - 208700, but these PCB's are different, in that the components on the old part sit in the actual airpath of the exhaust air, whereas on the new part, 208700, the main components are on the other side, out of the airflow path.
I'm wondering if the carbon dust from the motor exhaust gets over the components of the old type boards and causes them damage, and possible shorting out? just a thought?
This is the old type board - note that the wire connectors are on the back, so that the main parts of the board are facing into the exhaust air flow
