Kirby Heritage/Legend Series 13" Nozzle
kirbyclassiciii
Milwaukie, Oregon
Does anyone here know anything about parts diagrams for the optional 13" nozzle for the Kirby Heritage/Legend series (1981-1990)?
Why do I ask? It is not made mention of in the Heritage II Nozzle Group exploded view (only the standard 16" nozzle is).
Thank you,
Benjamin "Ben" Edge
The Small Powerhead
Kirby didn't publish anything separate for the optional smaller powerhead. The Belt Lifter assembly all still went together the same and for the most part so did all of the other components. Not enough of the smaller size powerheads were sold to make it cost effective to publish separte information for it.
There is, of course, that extra nodule on the back side as to accommodate the Heritage/Legend series safety switch (the older versions of this nozzle casting for models 513 to D80 will not work on the Heritage/Legend series w/o modification.
I'd love to know what the part number is on the casting for the Heritage/Legend 13" nozzle... if ever there is one. I'd like to think it reads 140982.
~Ben[this post was last edited: 4/5/2013-13:05]
Brad (IL-Kirby-Fan),
While Kirby may not have moved enough Heritage/Legend orders with the 13" head to justify a separate parts breakdown for it, they did, however, publish separate information for Heritage II models with the older Sani Em-Tor. It's the one marked "POCKET BAG WITH LARGE EMTOR."
My favorite Legend II nozzle
<span style="font-family: verdana,geneva; font-size: x-small;">Here's my favorite Legend II nozzle. Its more compact and more streamlined nozzle makes it easier to use, and concentrates the suction a little bit more than the larger ones. </span>
<blockquote>
</blockquote>
Charles Lester
So good to see you on vacuumland!
Ben, I have 2 of the small nozzles. My first one has the heritage 2 turbo belt lifter on it and the number is 140062
kirbyduh, electrolux137
kirbyduh: Thank you for giving me the part # on its casting. I wonder how the same part # you found would still apply to the version of the nozzle, with the nodule that's there for the 134381 safety switch? I'd still like to wonder what the complete 13" Heritage nozzle part # is (entire nozzle plus brush roll)?
electrolux137: Welcome back, Charles!
I'd reason to think the old-style single-row brush roll #1551 was still being used for the 13" Heritage nozzle, right?
Model numbers.
There is a sticker with a number behind the bumper, would that be the number for the entire assembly? Both my small nozzles came with a multi row Brushroll.
According to Kirby through its official Facebook page, they say the complete nozzles (without brush roll) are part nos. 143382S (Heritage I), 143384S (Heritage II) and 143388S (Legend II).
The individual replacement parts are:
140182 - Nozzle bumper (1HD) (use 140483, cut to size)
140184 - Nozzle bumper (2HD) (use 140485, cut to size)
140188 - Nozzle bumper (LGII) (use 140488, cut to size)
140869 - Nozzle bumper rivet (all)
143179 - Air adjusting plate (early 1HD)
144081 - Belt lifter cap casting (1HD)
144084 - Belt lifter cap casting (2HD)
144088 - Belt lifter cap casting (LGII)
144181 - Belt lifter spring washer (all)
144281 - Belt lifter cap hook (all) (use 144291)
144681 - Belt lifter cap spring (all)
144781 - Belt lifter mounting screw (all)
145481 - Belt lifter bearing (all)
146381 - Belt lifter top label (1HD)
146384 - Belt lifter top label (2HD)
146388 - Belt lifter top label (LGII)
146681 - Instruction decal (1HD)
146684 - Instruction decal (2HD)
146688 - Instruction decal (LGII)
146781 - Belt lifter bottom label (1HD)
146784 - Belt lifter bottom label (2HD)
146788 - Belt lifter bottom label (LGII)
148282 - Quadra-Sweep brush roll (all) (use 500505)
154169 - Brush roll adjusting screw (all)
154456S - Rug plate with gasket (all)
1545 - Rug plate hinge rivet (all)
1547 - Rug plate hinge (all)
1548S - Rug plate gasket set (all)
301282 - Belt (all) (use 301291)
Corrected Parts List
Brad (IL-Kirby-Fan), Lane (kirbyduh) and all,
The individual replacement parts (this time with corrected part numbers) for these 13" nozzles are:
Model code:
1HD = Heritage
H84 = Heritage 84
2HD = Heritage II
LI = Heritage II Legend
LII = Legend II
143382S - Nozzle complete less brush (1HD)
143383S - Nozzle complete less brush (H84)
143384S - Nozzle complete less brush (2HD)
143387S - Nozzle complete less brush (LI)
143388S - Nozzle complete less brush (LII)
144081 - Belt lifter cap casting (1HD/H84)
144084 - Belt lifter cap casting (2HD/LI)
144088 - Belt lifter cap casting (LII)
146381 - Belt lifter top label (1HD/H84)
146387 - Belt lifter top label (LI)
146388 - Belt lifter top label (LII)
146681 - Instruction decal (1HD) (use 146684)
146783 - Belt lifter bottom label (H84)
146788 - Belt lifter bottom label (LII)
147982 - Nozzle bumper (1HD) (use 140483, cut to size)
147984 - Nozzle bumper (2HD) (use 140486, cut to size)
147988 - Nozzle bumper (LGII) (use 140488, cut to size)
* 153471 - Brush bearing retainer (all)
* 153571 - Brush bearing, bronze (all)
* 1539 - Brush end cap, small (all)
* 1540 - Brush end cap, large (all)
* 155281 - Brush end cap sleeve, white (all)
159056 - Belt (all; factory installation)
500505 - Quadra-Sweep brush roll (all) (NLA; procure NOS)
* For brush rolls equipped with sleeve bearings and removable end caps.
