Would a Wessel Werk turbine tool be a good investment for car cleaning?
royalfan103
Bremerton, Washington
I’ve been looking at Wessel Werk turbine tools because the ones on my Maytag Hoovers aren’t cutting it. I’ve heard that they make Sebo’s turbine tools and I’ve been thinking about getting one or two for my Shop Vacs for usage on floors, upholstery, stairs, and my family’s cars (We have a dog that sheds a lot and my pickup truck has a lot of her fur on the floor.).
Are these good tools to invest in? Or should I get something else for if I want to use my Shop Vacs for the uses I described above?
I would say go for it, they're well made. I like either the Wessel Werk or the RugRat. The rugRat is louder and more aggressive, and the Wessel is quieter and not as aggressive on whatever you're running it on, and typically run better on things with less power than a central vac. If you want a really nice larger one for the floor, the Wessel Werk TK286 is extremely nice, and runs on bare floors and rugs equally well. My recommendation is probably get both the small and the large Wessel Werk.
http://wessel-werkusa.com/wwusa/pt-160/
https://www.wessel-werk.com/en/products/turbo-nozzles/tk-286
Okay, so, I’m about to get the Sebo version of the Pt160 from my local vacuum dealer tomorrow (Online is kinda iffy for finding a genuine one). Would a Windtunnel (Maytag Era) drive one of these things?
I have the Wessel Werk (Miele) turbo nozzle. The nozzle cleans well, I find that I use the turbo more than the small electric nozzle on a canister, such as the side kick. I will say that the Wessel Werk tool on my X4 is awful.
The turbo tool VAPamore sells with their MR500 Vento canister vacuum is surprisingly good. I normally prefer a powered upholstery brush like a Sidekick or Pet Powermate but the air powered tool VAPamore sells is actually very good.
Scroll all the way to the bottom of the link to find spares and attachments, then arrow to the right to find the "MR-500 Vento Small detail floorhead rotary brush". Only $25 too.
https://vapamore.com/products/mr-500-vento-canister-vacuum
I have a Filter Queen mini power nozzle with a motor as I am not a fan of air drive nozzles. Milwaukee makes an M12 powered universal nozzle. Pretty cool tool as I run all Milwaukee M18 and M12 power tools but will be staying with my FQ.
Maybe thatone.
But you're right cords beat cordless on most jobs historically. Used all corded tools until 2019, then went to Milwaukee M18 in 2022 because I only used my cordless tools. So I sold everything else and went to the high powered cordless and eliminated a whole bunch of bulk. When I lived at home I had a workshop, and don't have one now.
I think battery is fine for something like a drill or maybe a very small impact, that is because I have to crawl around under a house or try not to fall through the ceiling with a central vac install. If I am unscrewing a vacuum, I don't need all that power. So there is use for both.
For sure. For example I want corded hair clippers. Don't want dead clippers halfway through a haircut
We have cordless hair clippers, they only work when plugged in though. They are meant to be battery or mains.
Buy an Oster 76 detachable and you will have them forever. Costly but worth it. I have all 11 blades to go with plus a 10 piece guard set. Bought them in 2020 and they cut very good and have the ability to cut through anything. They will cut nice fades
Absolutely.
Speaking from experience. I used my Wessel Wero turbo tool with my Henry to clean out my mom's car once. It made light work of that task. Before that, I was using a 2 gallon Shop Vac with the port-end of a Eureka Bravo hose. Needless to say, the Henry was a massive upgrade.
I have one like the Sebo, but it's another generic brand sold by a central vac dealer. Easy to clean the turbo fan and belt. Rugrat is/was another type.
For sure but I want a dedicated motor as it is a mini of my full size. I buy the older Filter Queens because that is what I use, and collecting is an afterthought.
Having matching everything is a very nice feeling.
I am big on systems. All of my tools are Milwaukee M18, kitchen stuff is all KitchenAid compatible, landscape stuff runs on an Echo PAS engine (their version of a Kombimotor) and I interchange tools with 1 engine and my detachable hair clippers are Oster 70 series compatible.
Call me a Philistine but the turbo brush that comes with the VAPamore ( CRAPamore ) MR500 Vento is maybe the best turbo brush out there and they are inexpensive too.
