ElectroLux Sidekick compatibility
vap0rtranz
Wisconsin
Hi folks,
Which hoses does a Sidekick work with? Only the original OEM hose??
I grabbed a Sidekick off eBay (#1562) and it does not fit my Electrolux SuperJ's replacement hose.
When I try to slide on the Sidekick, it will not lock into place. The hose's electric mating part (with female pins) doesn't slide all the way into the Sidekick's (the part male pins).
My replacement hose fits perfectly for the carpet powernozzle (a PN-2), and has worked for years.
The Sidekick's electric pins are not bent. Everything loose square to me.
What could be the problem?
Thanks,
JP
Hi folks,
Thanks,
JP
I have the same issue. I have two aftermarket hoses that are for the super style machines. The side kick will not work on one of them. My newest aftermarket hoses will power the sidekick, but you have to really push and angle the handle down for the sidekick to attach properly. Sometimes it’s also hard to get the sidekick kick off. Eventually I might get a genuine hose that fits the Aerus classic.
I have an aftermarket hose for my Silverado that fits the PN5 wand and I use a second generation Kenmore Pet Powermate with it.
It will work on an AP style hose. On the generic electric hose i got, i had to kind of wiggle it in. Eventually it went through. Sidekick strong plastic, but at the electrical male part, it had some skid marks, not much. Now it goes in just as good as it did using an AP style hose. Maybe it would work on other generic hoses, but for mine i kind of hat to wiggle it in. This Sidekick works really well. Especially when I'm cleaning the cat houses, where they can sleep, and scratch the side. The tower looking ones. Oh and very good on the couches.
I love my Sidekicks, and I have seen this issue with third party hoses reported more than once in the past, but it hasn't been that big of an issue for me. I have two generic hoses and a whole bunch of OEM ones, so the odds are I'm using an OEM hose. But with the generic ones, I find they they work okay if you wiggle them securely onto the plug.
What I find more confusing that with a generic hose is you have a plethora of power switches to contend with, and it's really easy to have all but one of them turned off. There's a switch on the vacuum, a switch on the hose, and in most cases, a switch on the Sidekick. It's confusing enough with an OEM hose, which would give you two switches to worry about, but when you throw in a third, it seems like the complexity level increases exponentially. And of course, this phenomenon is not limited to Sidekicks, as newer Electrolux/Aerus power nozzles (PN6 or 7 and newer) also have their own power switches as well.
A lot of the time the thickness on the rubber plug for the power terminals can affect the operation of accessories, its not made to original OEM spec so it can be slightly thicker to the point where it wont want to go in.
Dog hair on couches and cars is what I'm hoping to use the Sidekick for too.
What is the AP style hose?
Yea, I feel like if I really push the plastic/rubber around, then the Sidekick's power port might slip in. It seems to really be the power part that is at the wrong angle/position. But I don't want to break anything. Plus ... getting the Sidekick back off, as you say.
The AP hose is used for the Canadian Electrolux vacuums, like the AP100 200 280, the E-2000 model E-2100, and later models. They might not have called them AP hoses in the latest models. I just refer to the thoses as AP hoses. Maybe it's just me! I should say the OEM AP hose is what works. no issues, as i have one from the AP 100 and E-2000 series. Ah, a better word, AP style hose. I just woke up. Need more coffee! I got the Proctor Silex one from the 80's. Brand new old stock. The one with the brew selector. My grandmother had this model in the 80s 90s. When i turned this thing on, wow what a difference to todays coffeemakers. Maybe it's just me, but this is what you call an awesome automatic drip coffeemaker. If i was older at the time my grandmothers broke down. The tube at the bottom got worn out, so when u pour water over, it would just come out of the bottom. But if i was older, i would have taken the bottom out, and replace with a new tube. You see the screws at the bottom my grandpa didn't have the type. Early on in my adult life i got one, long story short this happened to me. So if there's a will there's a way, i opened the bottom, replaced the tube and continued working great. This is the A4 something model. sorry i brought this topic into a vacuum cleaner discussion. I also love the unique sound it makes at the end of the brewing cycle. hehe yes i'm weird. But they sure don't make these today. it's buy use for 2 months, and throw away.
    11.3 KB
I have an old Proctor Silex drip coffee makers just like that I need to replace the switch in.
Didn't some Canadian Electrolux models have a different hose connection from that used on US models?
Yes they did. The Canadian Electrolux hose has a bigger diameter on the end of the hose that plugs into the vacuum cleaner. My apologies, I try to explain things best as I can! I love the beauty of the cloth hoses. I think I said in earlier reply, todays hoses are all the same. Dull and boring. My grade six teacher would say, we need excitement here! My friend has an AP200 Canadian Electrolux hose. It sucks find believe it or not. The thing is the power nozzle shuts on and off. You have to hold the hose kind of in an upright position. It's a great hose for the other accessories, like the swivel floor brush, the round brush for doing the edge of the floor. Usually the swivel hose brush picks up everything in the corners. Baseboards. I just like to change attachments for fun. I think i got that idea when i was look at round brush part in the owner's manual. I just like how the colour of the hoses of the vacuum cleaners matches the colour of the vacuum cleaner body, accessories, and the Handikit. I know the first original version of the AP100 hose had the power trigger on the handgrip, with the Power Nozzle V. Telescopic Wand. Then in the next version of the AP100 hose they removed the power trigger, and did the same as in the AP200. Brought it back again in the E-2000. The first version of the E-2100 had the power trigger on the handgrip (i should mention to stop and stop the powerhead nozzle motor) then on later versions of the E2100 and later versions of Canadian Electrolux cleaners they removed that trigger completely. Did anyone experience using the power trigger on the handgrip of the electric hose. If you did do you like that feature, or prefer to have the power head turn on when u turn on vacuum cleaner. Just curious. :)
Yes! That way you don't have to shut off vacuum if you, let's say for example, want to attach the swivel floor brush to do some cleaning from carpet to floor, or any attachment If the powerhead is running (electricity going from vacuum to hose to powerhead) and you unplug the cord that is attached to it, while it's running, the male end prongs will shorten over time. I read this somewhere years ago, and actually this has happened to me. Thankfully one day i decided to do some research, and i discovered an article explaining this. The prongs on the end of my powerhead cord have shortened, but i still can fit it in enough for it to stay put. My sister's vacuum, same thing, Totally different brand vacuum cleaner, and she had same issue. i had to end up cutting the old plug and put another one in from another power nozzle of that brand. Then she was good to go. I told her about this. To this day everything is fine. I hope i'm using the correct terminology when i'm describing these detachable powerhead cords. I'm glad i found this place. I have learned so much! This is why i like having some kind of option to shut off the power nozzle while i'm cleaning, switching nozzles, whether it's the power trigger on the handgrip of the hose (like the AP 280 Electrolux Vacuum cleaner), or a on/off switch on the generic one which i have.
Electrolux/Lux NZ hoses have always been very different, usually white braided exteriors with everything from dark blue to bright orange highlights woven through.
I have some of those. They are old school Electrolux. I haven't seen a white one that has electric wires in it tho. I have three of the white ones and they all have to have the power cord clipped to the outside of the hose.
I love that hose! It is colourful and reminds me of the vintage Electrolux vacuum cleaner hoses. Made in Germany. The craftsmanship of this clean is so cool.
So that vacuum is a bog standard 120 volt Aerus Guardian Platinum wearing the blue skins for the early Lux D920. The hose is from an AP-11 Intelligence Premium. I removed the Bluetooth controller on the hose handle and replaced it with the simple on-off switch from the Lux Powerprof silver vinyl electric hose ( an accessory for the Powerprof commercial tank in the event you want to use it with a power nozzle ). The Aerus version of this vacuum is the same basic flavor sold in Europe as the Intelligence Classic or D920 depending on the market. They were sold suction only, no Bluetooth, simpler display, but had the electrical connection for a powered hose and could use the Powerprof hose. The wand if from an Intelligence Premium and the Sebo ET-1 is a normal US model with a neck from an Australian version of the Intelligence that was sold with the ET-1. This is how Aerus should have sold these in the US IMHO.
