That would definitely work!
That is the pre-World War II version of the model 200. They only made them for three years before the war. All of the pre-war serial numbers that I've seen are five digits or less. They probably didn't make more than 60,000 of them before the war.here is a picture from aView attachment 171924
Thanks for the update on timeframe, that gives a date range to mash into the search. It's always more productive if you have a specific year to go with the search.That is the pre-World War II version of the model 200. They only made them for three years before the war. All of the pre-war serial numbers that I've seen are five digits or less. They probably didn't make more than 60,000 of them before the war.
Unless it is a model 200, the air comes out underneath the switch pedal in a strong stream, and through the foam silence ring in a much less strong stream. I've been collecting filter queens for 50 years now, one of my favorite machines with the exception of emptying it. But hey, that's what the "seal guard" filter cones were for with the plastic bag bonded onto them.On my nana's one there is a foam ring and a big hole on the top. The air goes out the hole, where the hose is attached for blowing. But there is a removable cap on top, that forces the air to go down into the foam.
Those are some nice machines!Unless it is a model 200, the air comes out underneath the switch pedal in a strong stream, and through the foam silence ring in a much less strong stream. I've been collecting filter queens for 50 years now, one of my favorite machines with the exception of emptying it. But hey, that's what the "seal guard" filter cones were for with the plastic bag bonded onto them.View attachment 172046View attachment 172047View attachment 172048View attachment 172049View attachment 172050View attachment 172051
