I've been Metrovac'ed
cheesewonton
Sandberg
I have been curious about Metrovacs for a long time but the price always put me off and used ones almost never turn up on eBay. However I recently had an opportunity to buy a new Metrovac Evolution two-speed canister and power nozzle for about half price from a freight liquidator in the Midwest so I swooped. I have only used it once but here are my initial impressions, but first the suction and airflow I measured.
Sealed suction is only 58 inches of water lift measured at the hose end. There are no audible leaks and I let the number stabilize to ensure that was all it had.
Airflow: The inside diameter of the hose opening is 1.1 inches ( same number for pretty much all the "1 1/4 inch" hose ends. Inside diameter is always less. Measured airspeed is 5800 feet per minute. That yields an airflow of about 31 cfm.
For comparison a Tristar DXL produces about 62-64 inches of water lift at the hose end and 27-28 cfm airflow also at the hose end. A Patriot has the same suction and maybe 30 cfm airflow. My VAPamore ( CRAPamore ) MR500 Vento manages 80-82 inches of water lift at the hose end but the same mediocre 31 cfm airflow. My Riccar 1700 produces a prodigious 92 inches of water lift at the hose end but a disappointing 30-31 cfm airflow. I can't get a good suction reading from our Kenmore 600 due to the weird shape of the hose end but it produces a healthy 72 cfm at the hose end.
So what's it like to use? It is surprisingly light for an all steel vacuum with a two stage 5.7 inch Ametek motor. It rolls easily on four nice big wheels, much like an old Tristar in that regard. It doesn't roll over and play dead like a lot of modern canister vacs with top mounted swivel hoses ( Miele ! ). The hose is only 6 1/2 feet long, shorter than I like but no worse than pretty much every Tristar, Electrolux or Miele. It is not as loud as I expected and most of what you hear is the woosh of air coming out the exhaust. The cord is only 25 feet so I have to use three plugs to accomplish my normal cleaning where with a Kenmore, Sebo C3.1, Tristar, Patriot or the Aerus Guardian Platinum I can use just one plug and reach everything. A ten foot long hose would solve the problem. The power nozzle connects to the hose handle with a pig tail. The female plug on the hose handle is not recessed so there is no shroud around the contact pins. The plug on the cord that comes with the power nozzle is a stretchy coiled cord that kept pulling out of the socket on the hose handle. The contact pins fit kind of loose too. I have a short pigtail I dug up and squeezed the contact pins ever so slightly oval with some pliers and used that to lengthen the cord a bit and get a better contact with the hose handle. That works better. The hose end and upper wand should really be direct connect. I may come up with something in the fullness of time since the handle looks like something Hayden used to use.
The power nozzle was a pleasant surprise. It is extremely quiet and does the job better than my Miele or Wessel-Werk power nozzles. Aside from the connection to the hose the only thing that feels like it might not last is the height adjuster. I normally use my hand to operate height adjusters but this one requires too much pressure for my hand. Even using my foot you really have to step down on the pedal and it makes an uncomfortably loud click as you move through the height selections. This is the part that feels like it will fail if you use it a lot. Fortunately it seemed to clean our rugs well on one setting so that is where I shall leave it.
The decal on the body claims six stages of HEPA filtration but I can only count four, the disposable bag, the inner cloth bag, a foam pre-motor filter that sits in front of a thick pleated HEPA filter over the motor. There is no exhaust filter of any kind unless I am missing it. The only disposable bag Metrovac offers is paper. No bueno! I trimmed the mounting card of a Vortech XR3000 synthetic dust bag and use that. The mounting card on the Vortech bag is just ever so slightly thicker than the OEM bag so the lid latches very tight. On the next bag I will try squeezing down the cardboard a bit to make it thinner so as not to put too much strain on the bag lid latches.
I haven't tried this yet, but I have an aftermarket Electrolux hose with the exact same handle on it that plugs into a traditional Electrolux upper wand. The steel spout is very slightly different though. I will test the Metrovac with my PN5 to see if it makes the connection and stays connected. If so I have a work around for the balky pigtail. Stay tuned for updates.
So there it is. Kind of a relic in a way, more like an old Royal than any modern vacuum. Modest performance by modern standards but no worse than Patriot sells for three times the price, and all steel. Given reasonable care it would probably last the life of most owners. Even the cheap Chinese power nozzle is better than I expected and a lot more civilized to use than a Eureka Rugmuncher or even a Riccar PB100. Did I say I like how easily it rolls?
    1,022.5 KB
    916.8 KB
    1.1 MB
    1 MB
    1.1 MB
This looks very interesting! Nice find.
I like stuff that is simple but well made. All you need and nothing more but durable and trouble free. The less stuff the less to fail. The fit and finish, the quality of the fasteners, are all very nice. In the fullness of time I will probably replace the dusting and fabric brushes with something nicer but that is not a priority. I'm thinking I have some black vintage Eureka attachments in the garage if I go digging including one of their nice horse hair dusting brushes. And I will probably fool around trying to come up with a way to achieve a direct connection from the hose to the wand. But nothing urgent. It works fine just as it is.
I just applaud the fact that one can still buy a nice, high quality all metal canister vacuum that's made in the US. And as a bonus you buy it on line instead of having some creep come into your home and try to bend you over on price like Kirby does.
OoOh, fancy.
It's anything but fancy really. Just a simple steel tube with a motor in the back. Rugsucker calls it a stove pipe with a motor. No cord winder, just a big spool to wrap the cord around. About as simple as one can make a vacuum cleaner. But it is all steel and that is nice.
My only experience with a 'Metro' is one of their Electrolux rebuilds. Same company. I've got an old LX that went through their facility back in the day, and that same philosophy shows through--Cut out everything that doesn't absolutely have to be there. They stripped off the cord winder, bag ejector, holders for the tools and the extra bag, everything, added a cheap plastic hose and some generic tools, gave it a bad rattle can looking paint job, and sent it out the door. I couldn't leave well enough alone, so I added a cord halo to the back end for a practical and aesthetically pleasing upgrade. Looking at the photos of the Metropolitan, I don't think anybody could accuse them of infringing on any of Electrolux's patents, but you can tell where they got their basic idea from.
The Evolution looks a lot more like an old Royal 400 series than anything from Electrolux.
I had a poke around and shrivelled up at the price.
Their vacuums are all steel and they are all made in the US. Their prices are lower than Aerus, Tristar, Patriot ( which are plastic ), Filter Queen, or the very similar Air Tec BG2000 I think it's called. I don't mind paying a bit more for a quality US made product. The hoses are made in South Carolina too. Only the power nozzle is Chinese and it is surprisingly good.
