Needing answers to some questions
centralsweeper63
Christchurch, New Zealand
For a we bit now I have been wanting to work on making a prototype vacuum that I could slowly work on. What would you guys want in a vacuum. I was thinking a cylinder with shapes and designs vaguely inspired by things like nilfisk, Electrolux, Hoover, ge, etc. I want to hear your ideas and suggestions. I would also like to hear if you think it would have a market. If you have anything to add or any ideas I would love to hear.
From experience, larger diameter hoses and wands, on the order of 38-40 mm diameter, maximize airflow. Some modern Japanese canister vacuums use hoses as large as 48 mm inside diameter! Modern Hitachi hoses are 48 mm at the canister end and 46 mm at the hose handle. Also, gentle curves on hose ends and swivels, help airflow. Sharp bends like those old pistol grip handles that Electrolux and Tristar used are death to airflow. Keep the airflow through the vacuum as close to linear as possible. Hoses that attach to the front of the vacuum instead of a top mounted swivel flow better. Also those top mounted swivels often cause the vacuum to tip over when the hose is 90 degrees to the body. An expander cage to keep the bag off the sides of the bag chamber helps maintain maximum airflow as the bag fills up. Look at a Hitachi Karupack canister and the Panasonic MC-PA20, MC-PA21 and MC-PA22 canister vacuums, all of these are Japanese market canisters, for what a vacuum with high airflow looks like and the Panasonics have the kind of expander cage I am talking about. Scale these up a bit for a longer cord, longer cord and a bit more bag chamber capacity and you would have a winner I think.
I like your ideas. I will link a very primitive list I chucked together today.
Metal casing optional
Paper or cloth bags available
Cloth support bag
Reusable bag option
Unrestrictive to airflow “freeflow design”
Swivel castors
Ways to appeal to kids
Bumper
Good edge cleaning
Easy to access switch
Sleek design
Bag check indicator
Filter shaker
Large capacity
Suction control
Mechanical feel
Castor wheels
Nice colours
Follows you easily
Easy change bag
Sloped design
Large fan diameter
Beater bars
Easy switching between floor types
Stiff bristles on the power head
Hepa filters
Large diameter brushroll
Highly curved brush rows
Large amounts of cfm
Separate motorized upholstery tool
Hybrid technology
Swivel steering
12 metre cable on deluxe models
Anti microbial parts
Odor control filters
Energy efficient
Minimal plastic
Easy to repair
10 year warranty
Below 70 decibels
Entire brushroll AREA is clear
Aroma diffusers
Rebuildable motors
Brushless motors
Off the shelf parts
Headlight
Detachable cord
Phillips screws
Repair guide, exploded diagram, parts list, maintenance guide and manual printed and in the box with the machine and available online.
Manual suction control potentially.
Bag check indicator
Height adjustment
Manual cord winder
Mechanical thermal cutout that stops the vacuum from working if heat builds up
Screwdriver stored inside the machine
Brushed metal finish
Large, angled chrome vents on the top/ 60s faux cane plastic
Exposed screws
Embossed logo on the metal
Brushroll with replaceable bristles
Full colour retro HAND-SCHETCHED boxes
Metal warranty card
Servicing record card in box
Grease in the box
Spare parts in the box
Spare set of screws so that if a screw is lost it is fine
Cogged belt
Spare belt
Metal tools
Door hanger
Satisfying switch clicks
Deep hum
Sound deteaning
Limited edition retro colours (harvest gold, avocado green etc)
Titanium base plate
